koopas
Aerospace
- Aug 24, 2002
- 106
Hello all,
This question has been troubling me for a while...
How would you calculate the joint bearing allowable of a single shear joint, IF the tested joint allowable for your particular configuration was not available from MIL-HDBK 5 or the SRM's?
It's been beaten into me that using Fbru*d*t is not recommended in single shear joints since the Fbru value is obtained from a double shear test. Using Fbru in single shear joints greatly over-estimates the joint strength.
Is there some sort of correction or knock-down factor to reduce Fbru in single-shear joints? What do you guys/gals do?
Last resort to find out the joint's bearing strength would be to use the shear-out or tear-out equation based on material Fsu but I'd rather not go down that road.
I am dumbfounded.
Thanks for your help.
Alex
I am dumbfounded.
Alex
