Gusset plate design for pin load 1
umr10
3
In the construction field, we use quite a few single pin connections for our temporary support structures. How should I design the gussets for this single pin load. I'm familiar with the Whitmore section but because I have a single pin transfering the load(compression) into the gusset I'm not sure how to develop the load in the gusset. We typically design with ASD. Normally I would look at the tribitary area produced by the Whitmore section (60 deg included angle) and get a compressive stress. Then I'd look at the gusset plate as a column with its lenght from the end of the connected part to the column for example. But with a single pin, I'm a bit lost.
What is the diameter of the pin, you would need to check bearing on the plate, if the plate goes into tension you would have to check shear/tension rupture. If you want to treat the plate as a column (which seems reasonalbe) with the whitmore section, maybe use the average width of the whitmore section as the column and see how you stand, if its a tight design, go to a thicker plate.
That sounds resonable APETR26542 (the average whitmore area). That was what I was leaning towards.
This connection will typically be in compression.
I'm looking at a 2-1/2" pin diameter. Thanks.
