skasliwal
- Apr 1, 2005
- 10
Can somebody suggest the procedure to carry out external pressure design for temperatures outside the range of External presssure chart.
I have design temperature of 1130° F and the yeild stress values are not listed at such high temperatures in 2-D. I believe that is what is causing the problem in calculating B-factor. Can I use the minimum yeild stree value listed in 2-D to carry my calculations.
Any suggestions will be greatly appreciated.
