When PE pipe is thermal welded the weld leaves a bead inside the pipe.
How much does this bead effect the pressure drop down the pipe?
We have line (90mm OD 10mm wall) that does not flow any where near the flow it should but the pressure drop calculation did not include the effect of the weld bend.
