To Round a Measure
Akesson
134
SE
I would like to round a measure in a formula using the "round()" function under Math.
The problem is that I would like to set the number of decimals to use. Not always round to nearest integer.
Example; 13,478mm to 13,5mm (not 13mm)
Anyone who knows how to do this?
/Akesson
Why don't you multiply / divide your value to have the round() you want :
Real.2 = Round(10 * Real.1) / 10
Eric N.
Thanks for the solution!
Best regards
Akesson
