stanier
- May 20, 2001
- 2,442
The celerity of a thermoplastic material is lower than for rigid materials. However in a buried pipeline it is considered that the soil support will provide some increase in modulus of the pipe/soil combined structure.
In modelling such pipelines for surge most profesional software packages allow the modelling of a circular tunnel. This assumes that the material doesnt deform when such a pressure wave travels along the pipe and thus the celerity is similar to that of a rigid material.
The modulus of soils is however low compared even to thermoplastic materials. So one may argue it has no bearing. On the other hand the response of viscoelastic materials such as soils is strain rate dependent and may actually have higher moduli than found in the labratory for rapid waves.
Do Forum memebers know of any research texts or books that cover the topic of the effects of soil embedment on celerity of low modulus materials in pipelines?
