Can someone please explain to me the rationale behind the disparity in maximum allowable temperature between low-carbon austenitic stainless steel such as 304L and 316L, and the "regular" carbon grades (304, 316)? 304L and 316L are limited to 850F for Sec. VIII Div. 1 use, whereas 304 and 316 are allowed up to 1500F. Everything I've found indicates that the strength vs. temperature drops off at about the same rate - so is it due to creep resistance? I realize that the advantage of using low-carbon grades - increased resistance to sensitization - is no longer an advantage when the material sees those temperature over a prolonged period of time, but that does not explain to me why its use is precluded above 850F.
Anyone know?
Best Regards,
Jeroen Valensa, P.E.
Anyone know?
Best Regards,
