Config.WIN File
cam721
26
What is the config option to load a specific config.WIN file? I have setup ProE the way I like and would like it to load that way every time I log on.
Wildfire 2.0
Thanks!
-Art
cam 721,
pretty sure if it is in the start in directory that your windows shortcut uses to launch ProE it will get read everytime.. I don't think there is a config option that point to a .win file
There isnt a config option to control the config.win. cadcamguy is correct, just put it in the startup directory. if you cruise thru the documentation it tells you that you can put a config.win in the <loadpoint>/text directory to control the corporate look. disregard that, it never worked as PTC intended that to work.
Fighter Pilot
Manufacturing Engineer
You can customize the look and feel of Pro/ENGINEER and the way in which Pro/ENGINEER runs by setting options in a configuration file. Pro/ENGINEER contains two important configuration files: config.pro and config.win. The config.pro file is a text file that stores all of the settings that define the way in which Pro/ENGINEER handles operations. The config.win file is a database file that stores window configuration settings, such as toolbar visibility settings and Model Tree location settings. Each setting in the configuration files is called a configuration option. Pro/ENGINEER provides default values for each option. You can set or change the configuration options. Some of the options you can set are:
• Tolerance display formats
• Calculation accuracy
• The number of digits used in sketcher dimensions
• Toolbar contents
• Relative button order on a toolbar
• Location and size of the Model Tree
A Note About config.sup
Config.sup is a protected system configuration file. Your company system administrator uses this file to set configuration options that are used on a company-wide basis. Any values that are set in this file cannot be overridden by other (more local) config.pro or config.win files.
How Pro/ENGINEER Reads Configuration Files at Startup
Pro/ENGINEER reads configuration files automatically from several areas. If a particular option is present in more than one configuration file, Pro/ENGINEER applies the most current setting.
At startup, Pro/ENGINEER first reads in a protected system configuration file called config.sup. It then searches for and reads in configuration files (config.pro and config.win) from the following directories in the following order:
1. loadpoint/text (loadpoint is the Pro/ENGINEER installation directory) ? Your system administrator may have put configuration files in this location to support company standards for windows configuration settings, formats and libraries. Any user starting Pro/ENGINEER from this loadpoint uses the values in this file.
2. Login directory ? This is the home directory for your login ID. Placing your configuration files here lets you start Pro/ENGINEER from any directory without having a copy of the files in each directory.
3. Startup directory ? This is your current or working directory when you start Pro/ENGINEER.
Notes: The local config.pro and config.win files (in your startup directory) are the last to be read; therefore, they override any conflicting configuration file option entries. The config.pro file does not, however, override any config.sup entries.
You can create and store custom configuration files in your current working directory. These custom configuration files usually apply to specific projects.
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 4.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
o
_`\(,_
(_)/ (_)
"There is no trouble so great or grave that cannot be much diminished by a nice cup of tea" Bernard-Paul Heroux
You can also load a specific config.win from the customize screen window, in case you don't have write priviledges to loadpoint directory.
Michael
