Geometric elements (lines, curves, etc) disappear under solids. 1
l3ob
Aerospace
Apr 28, 2004
56
A couple of our guys have had the geometric elements disappear behind or under the solids in the models. Only the part of the line or curve that is exterior to the solid shows up. We don't know what caused the change nor can we find a visualization setting for this. They have had to delete the CatSettings to correct the problem. We are running R14.
Tools / Options / General / Display // visualization / Display element using Z-buffer = off
Eric N.
