Hello engineers!
I ve got an easy question for u, but this one is drivin me nuts...
So, i ve just bought a new flowmeter at Dwyer and the propose an equation to correct nonstandard operating conditions:
Q2=Q1x(sqrt(P1*T2/P2*T1)) (1)
EX:
a float sitting at 60 grad on the flowmeter scale have a exit pressure of 5psig, and exit temperature ate 85F, so the actual flowrate will be :68.8SCFH, with a flowrate calibrated with P1=14.7 psi and T1=530R...
BUT WHY THE DONT USE THE PERFECT GAS LAW: PV=NRT, i find the same formula, without the square root... Where is this square root in (1) coming from??
Thank you so much for an answer
EX:
