Building a ski/snowboard press 1
mcfridge
Industrial
CA
Hi everyone,
I have decided to build my own press for making skis/snowboards. There is a lot of information out there on how to do this: ,
These sites are a lot of trial and error, so I wanted to take more of an Engineering approach (this will be my first question of many). I have already chosen some steel I-beam for the frame, and they are getting cut and drilled next Friday. If you go to this page and go to the 6th & 7th pictures down, you can see a bunch of little bars strung together right under the top beam. They call this a cattrack, and it helps to distribute the pressure.
Now, I wanted to use Aluminum (because the press is already heavy enough) so I called a local place, and they had 1/2"x1/2" aluminum tubing, but the wall thickness was something like 1/16" (can't remember exactly). The "bladder" (a bag fille with air) pushes down on top of this with a maximum of probably 80 psi, over a length of about 90" and width of about 20". Is there a way to determine how thick the walls of these tubes should be to withstand the force? (sorry if this seems like a simple question, I'm having trouble with it). Is there any other recommendations on something I should try instead of these Aluminum bars? Thanks a lot.
If you pick a solid metal over tubing you should be safe.
Otherwise test a piece of tubing.
(P = F/A so P * A = F)
Cut 1/2" x 1/2" tubing by 1/2" long. A = 1/2 x 1/2 = 1/4 in^2
P * A = F so 80 psi * 1/4 in^2 = 20 pounds
So that 1/2" cut of tubing is going to be loaded with 20 pounds. To be safe it should hold more than 20.
A 2" long piece of tubing would have the area of 1 in^2 and be loaded with 80 pounds.
_______________________________________
Feeling frisky.........
