WillisV
- Apr 24, 2005
- 1,352
For the first time in the ACI-02 code cycle, the committee put in a provision requiring additional tie reinforcing at the top of columns and pedestals supporting steel columns with anchor bolts - see 7.10.5.6 which states in part:
"...the lateral reinforcement shall be distributed within 5 in. of the top of the column or pedestal, and shall consist of at least two No. 4 bars or three No. 3 bars."
Has everyone been meeting this provision???? It seems to be a horribly worded one for many reasons:
1. Typically no. 3 ties are much preferred for their ease of use, therefore with a 2" cover at the top of a pedestal it seems that you need to shove three No. 3 ties within a 3 inch distance.
2. This is another one of ACI's spectacular provisions that if you do not meet it, there is no recourse. What if I have 3 no. 3's within 6" of the top??? According to ACI that member does not meet code, period.
3. The use of the term column or pedestal is a bit ambiguous. Is a drilled pier a column? Typically they would be at least 36" and therefore much wider than the anchor bolt pattern. Is this steel still required?
Am I interpreting this correctly?
