  • Congratulations waross on being selected by the Tek-Tips community for having the most helpful posts in the forums last week. Way to Go!
Separator Vessel Nozzle Velocity and Momentum
bmp28
Chemical
Jul 14, 2003
0
GB
Hi guys,
I'm checking 2 phase separator vessel inlet nozzle velocity and momentum,, using various guidelines and refereces, but nothing conclusive.
One company internal guideline for separator inlet nozzle rho v2 suggests,
-No inlet device rho-v2 <1000 kg/ms²
-Pipe inlet device rho-v2 <1500 kg/ms²
-Vane type inlet device rho-v2 <6000 kg/ms²
When used inconjunction the velocity limits of 10-25 m/s for vapor and 8-15 for mixed phase flow, the rho v2 limits are breached.
Is there a guideline like API RP or Shell DEP that suggest the maximum velocity and momentum limitation in separators?
Which is governing, velocity or the momentum?
Thanks in advance,
bmp28
Please note that kg/(ms[sup]2[/sup]) = N/m[sup]2[/sup] = Pa, a pressure unit.
Wear by erosion depends on the impacting particle velocity and the angle of impingement. At a 20[sup]o[/sup] angle erosion may already be considerable.
For liquid droplets impinging on a solid surface at 90[sup]o[/sup] the pressure on impact is:
p = [&rho;] [&times;] v[sub]s[/sub] [&times;] v​
where:
p = pressure on impact [Pa];
[&rho;] = liquid density [kg/m[sup]3[/sup]];
v[sub]s[/sub] = sound velocity in liquid [m/s];
v = liquid droplet velocity [m/s].
As an example, for water droplets travelling at 100 m/s,
p = 1000[&times;]1500[&times;]100 = 150 [MPa] !​
Wear by impact can form holes or pits, and may even cause fracture if the material is brittle. This is a subject covered -among others- in tribology engineering books.
The following threads and the links therein may show to be helpful with regard to corrosive-erosive wear of piping:
thread794-57906
thread378-66050
thread378-64478
thread378-30500
thread338-23463
thread124-70976
