the perils of storm sewer design in the urban setting:
Whats the absolute minimum clearance between an existing 12" Cast Iron Class 22 water main and storm sewer. The storm sewer will most likely be a 48" inner diameter corrugated plastic pipe. I can get about 6" clear, can I encase the water main or should I encase the storm sewer?
or do I have to reloc the main?
(Btw the diameter specified for the CI pipe is the nominal Inisde Diameter or is the Outside Diameter?
