Majik
Automotive
- Mar 17, 2004
- 88
I've heard this several times that "Cold oil will cause engine damage"
I've yet to find any data to back this up though. The only specs I've found said that if temps were below 20F then warm the engine and oil up. With todays multiweight oils, I just can't think of something that cold oil (ie 85F) is going to hurt an engine. I'm not saying that cold oil like 0F can't hurt the engine. I've had customers tell me this for years that say that an oil temp at 130F will hurt an engine and 180F is the minimum you should run in an engine. Any truth to this?
