ardeIII
- Jul 28, 2006
- 4
On several centrifugal end suction pump of varying manufacturers, design conditions, etc., have recent problem of impeller nuts coming off shaft, followed by impeller, with associated damage to casing, impeller, shaft, etc.
Nuts are threaded opposite normal pump rotation direction and have retention devices (typically set screws). Check valves have been inspected and pumps are not known to run in reverse. Metallurgies are consistent ruling out loosening due to differences in thermal growth (several of the pumps are high temp-700 deg F range). Have looked for recommendations from OEMS on nut torquing values with common response being "tight is tight".
Compounding this problem, after couple of these events on one of the subject pumps, we modified the impeller nut to incorporate additional locking screws. Next time pump failed the shaft broke at the shoulder at the base of the thread relief.
Anyone seen this problem before? Any recommendations on nut torquing and locking devices?
