OS&Y Gate Valve 3
bbodman
What are the advantages, other than open/shut indication, of using an outside stem & yoke gate valve versus a non-rising stem type? Are they easier to maintain or more economical in some way?
Thanks rconner, Precisely the input I was looking for.
Thanks again
bbodman
The OS&Y valve is recommended in many cases in which anyone can see far away whether the valve is open or close. That indication allow, for instance, in fire protection systems to take quick action when the valve is closed and has to be open all the time.
We specify an OS&Y valves for high temperature service (>400F) to protect the seals.
