Images in ppt file
ferdo
RO
Maybe this will be useful for somebody. Lets suppose that you have a lot of images files (CATDrawings saved as jpg files for example) and you want to create a Microsoft presentation file. A quick way to create the ppt file is to use next macro in a blank presentation, with a blank landscape slide at start. Just create a folder named CATIA on C drive where you will put your image files (modify the macro if you have something else then jpg files or if you want to use another path) and copy-paste in VB editor in a new module what is written in the next rows. Be aware that the width and height of the slide is A0. After running the macro, you can open the My file.ppt saved in the same path (c:\CATIA\).
Sub INSERT()
' Macro by Ferdo
Set fs = Application.FileSearch
With fs
.LookIn = "c:\CATIA\"
.FileName = "*.JPG"
If .Execute(SortBy:=msoSortByFileName, _
SortOrder:=msoSortOrderDescending) > 0 Then
For i = 1 To .FoundFiles.Count
ActiveWindow.View.GotoSlide Index:=ActivePresentation.Slides.Add(Index:=2, Layout:=ppLayoutBlank).SlideIndex
ActiveWindow.Selection.SlideRange.Shapes.AddPicture(FileName:=.FoundFiles(i), LinkToFile:=msoFalse, SaveWithDocument:=msoTrue, Left:=0, Top:=0, Width:=1189, Height:=841).Select
Next
End If
End With
ActiveWindow.View.Zoom = 60
ActivePresentation.SaveAs FileName:="c:\CATIA\My file.ppt"
ActiveWindow.Close
End Sub
Fernando
