Custom Symbols (NX3)
phillpd
780
Couple of questions on Custom Symbols being used as a drawing format :
1. I have a custom symbol using a variety of different character sizes. When I add it to a new file however, all of the text becomes the same size. How do I prevent this from happening ?
2. How do I go about making changes to the custom symbol ? As in, redefine it, without going through the "create" process again ? Also, for text I define as "arbitrary", or "integer", can it be edited after the symbol has been inserted ?
Specialty Engineered Automation (SEA)
a UGS Foundation Partner
Found the answer to my first question, switch to use the "Definition Text Settings" icon.
For #1, go to File -> Utilities -> Customer Defaults... -> Drafting -> Other Symbols -> Custom, second item from the bottom, change the setting to 'Definition Text Settings'.
As for #2, I think you will have to go back and change your master "xxx.sym.prt" part file and update it. As for changing text after placing a symbol, if you've got some text that you really need to be able to edit or change, when you create the original symbol, create a notes that are linked to Attributes. Then all you have to do is edit the Attributes to update the imbedded text.
John R. Baker, P.E.
Product 'Evangelist'
UGS NX Product Line
SIEMENS
UGS PLM Software
Cypress, CA
John,
Thanks for the Customer Default. As for #2, I do use some Part Attributes. But then I noticed that when using Insert->Symbol->Custom Symbol, selecting an existing symbol allows you to edit it.
