gr2vessels
- Sep 29, 2004
- 1,971
Gents,
Here we go again.
Pls note that ASME VIII (2007 Edition) in Clause U-3 states that the "acceptable editions" of standards are nominated in Table U-3, and this Table references the superseded 1996 Edition of ASME B16.47 (large diameter steel flanges)and not the current 2006 version (which was published prior to the latest ASME VIII). We have had serious problems re-designing equipment because the AI required adherence to the ASME code requirements and the nominated editions in the ASME VIII did not allow the use of latest B16.xx edition.
I am unable to locate an errata to the ASME VIII (2007), which addresses this error. Would anyone know and be kind to advise, if ASME has issued some correction or at least a note about the incorrect reference, to be revised in a formal way?
cheers,
gr2vessels
Here we go again.
cheers,
gr2vessels
