I am looking for a specification or suggested procedure to cover a welding process joining a 316 SS pipe cap to a 4130 outer ring with a butt and/or fillet weld joint. Post weld, I would like to increase the yield strength of the 4130 by heat treatment. I seek any guidance for a heat treat procedure that won't significantly affect stainless component and weld filler properties. Thanks y'all.
Montec
Montec
