Einsteim
- Jan 10, 2008
- 76
Does anybody have information or a source regarding what appears to be a gypsum based structural roof? I visited a building today that has this type of roofing material with wire reinforcing embedded about a 1/3 up from the bottom...it appears to be around 3" thick. They may be prefabricated roofing panels. It spans roughly 1'-9" with embedded purlins. It has some sag that is quite evident. This building is likely 100+ years old. I have attached a picture from the underside.
The contractor wants to place a RTU that will add point loads AWAY from the steel trusses and directly on the gypsum material. I am not going to allow this, but thought maybe somebody would have some information on whatever this is ans some type of allowable loading information.
