slickdeals
- Apr 8, 2006
- 2,266
Greetings,
I am desiging 2 buildings separated by an expansion joint. I want to get some guidance as far as using Figure 6-9 of ASCE 7 to apply wind loads.
Here are my concerns:
Figure 6-9 applies to buildings with no exp. joints. How would you modify this to account for the fact that one of the sides would have a side wall pressure in addition to the positive and negative.
How would torsion be modeled? Does anyone know the origins of Figure 6-9. I am assuming the torsion is arising from a 45 degree wind (0.707W, which is conservatively upped to 0.75W??) However, any input you might have would help.
