Which Element to model STEEL CABLE? Please help!
richonlinedeal
19
Hello, Deal All,
Can anybody give me some hints which type of elements I should use to model Cable in ABAQUS? The cable could have different stiffness. Should I just use different E (Young's modulus) values to simulate this different stiffness? Thanks a lot.
Have a look at the "*No Compression" keyword (also in CAE, Material Options).
This can be used with just about any elastic element, but watch out for convergence problems.
Hello, MyMyers/All,
Forgot to ask you one more Q: If the Steel Cable is mainly to sustain Axial Tension but can bear little or no bending moment, is there any special Element I should choose? ALso, should I set the cable material to have a small Young's Modulus to achieve this? Thanks again.
Jerry
Or even hypoelasticity, with a very low modulus for strain in compression and a normal Modulus for strain in tension?
Using Truss element to model cable is hard to converge often.
-Jerry
