I'm using SW2007, trying to set up some basic drawing templates. For some reason I can't get the code to work properly when trying to auto-update things like part number and description when inserting a model view. I think I might be using older syntax, maybe? Does anyone have a directory of current SW2007 syntax?
Also, I'm trying to edit the tables, Rev and BOM to start, and I can't seem to figure out how to change the row height for the entire table to a default setting.
Thanks for your feedback!
