structurebeton
What is your opinion on a very long Lu and very tall upper roof, against a very small lower roof and in which the calculated drift width W ends up being a LOT larger than the lower roof width?
Would you then use the drift width W the same as the lower roof itself or would use a truncated snow drift shape? (Trapezoidal shape) Doing that would increase the snow drift load by a factor 6 or 7.
