Welding Duplex 2205 with SA 304
Donio
1
hello everybody. I have one question:
Is there problem at welding of Duplex 2205 with SA 304.
the vessel (130m2) is Duplex 2205 and his support beams is SA 304.
The temperature of the liquid is 90 °C
Thank you!
What does the Outokumpu welding guide recommend for 2205 to 304 welds? Check there first.
Plymouth Tube
For your purpose type AWS 309 Mo with low carbon content,is better choice than SA 304.
REGARDS
luismarques
It's a dissimilar welding, but there are no particular problems. Just foreseen a buttering with 309 electrode on the 304 and then complete the welding.
these articles can give u some good advise
DISSIMILAR METAL WELDS AND WELD JOINT DESIGN FOR DUPLEX
STAINLESS STEELS
PRACTICAL GUIDELINES FOR THE FABRICATION OF DUPLEX STAINLESS STEELS
S.
Corrosion Prevention & Corrosion Control
