sjohns4
- Sep 14, 2006
- 123
I have a text book pump station and force main - pump station at the low point of the profile, the discharge of the FM is at the high point of the profile to a MH, and there are a few ARV's at the intermediate high points.
We started the station up & did a drawdown, the pumps hit a point on the curve to indicate the pumps are working right, but we were not pumping as much as we should have been by design.
The pressure gauge (with the pumps off) indicated the static pressure was around 20' higher than it should have been. I had the profile surveyed, which matched the County's GIS topo +- a couple feet.
I'm wondering if an air pocket could be somehow causing a false gauge reading? Possibly from a faulty ARV?
It's a submersible station which by design should flow at 1200 GPM (using C=130 which should be conservative for PVC) with one pump through a 16" FM, but we're only getting around 950 GPM.
Any words of wisdom???
Mike
Mike
