ETABS - Braced Frame Beams
mcc202
Hi there,
I am new to ETABS.....I am modeling a braced frame building and I am having issues getting the lateral axial loads dumped into the horizontal beams of the braced frame. Any thoughts on why this is happening? I have been experimenting with modifying the beam properties and have no luck.
Release one end from the rigid diaphragm.
WillisV is right. To clarify, the beam will see no axial loads if a rigid diaphragm is used. You need to assign a semi-rigid diaphragm.
@WillisV,
Could you please confirm if that is what you intended or if there is an alternate way that you can share?
slick - I generally assign the points to the rigid diaphragm on a point by point basis (usually I just select them all to begin with and to go assign/joints/diaphragms)rather than by assigning the diaphragm to the slab itself. That way I can go to specific points and delete them from the diaphragm if I need to using assign/joists/diaphragms/none.
@ Slickdeals
As WillisV says, release one end from rigid diaphrgm, then you don't need to assign semi rigid diaphragm. I usually follow this method.
other way is offcourse assign semi rigid diaphragm.
Zee
