I am modeling an expension loop for steam distribution lines. What are the most fundamental steps that I need to take in order to complete a table of standard dimensions?
I have a Caesar II model that I intend to resize to generate different case scenarios and create a table. However, I'm not confident on using only the Allowable stress shown in Ceasar II.
How do I select Pressures and Temperatures in order to comply with ANSI classes?
thank you in advance
