State-transition matrix 3
BrCo
Marine/Ocean
Nov 16, 2006
11
Dear All,
I would appreciate your help.
I have a vector (e.g., x=[4 6 2 3 3 1 5 3 4] )
I need to calculate the state-transition matrix, that is, how many times does each number follow each number. In other words, what are the chances of 3 to come after 1, what are the chances of 2 to come after 5, etc.
This may seem easy in a small vector, but my vectors each have about 20,000 numbers, so an efficient system will help a lot.
Thanks!
Aren't you basically just calculating a histogram?
TTFN
FAQ731-376
A brute force program in Octave for 20000 numbers 1-6 took 2.2 seconds to run and 2 minutes to write.
The only line of interest in the entire exercise is
++x(z(i),z(i+1));
and that is about as interesting as lettuce.
Cheers
Greg Locock
SIG:please see FAQ731-376 for tips on how to make the best use of Eng-Tips.
The same prog in matlab runs in 0.016 s, although I had to rewrite the interesting line because matlab doesn't like ++.
So, how fast, exactly, do you need this algorithm to be?
Cheers
Greg Locock
Histogram it is. My first thought was this crude code:
clear
clc
x=1:6;
for i=1:2000
y(i)=randsample(x,1);
end
su=2000/6;
z1=zeros(1,6);
z2=z1;z3=z2;z4=z3;z5=z4;z6=z5;
for i=1:1999
if y(i)==1
for k=1:6
if y(i+1)==k
z1(k)=z1(k)+1;
end
end
end
if y(i)==2
for k=1:6
if y(i+1)==k
z2(k)=z2(k)+1;
end
end
end
if y(i)==3
for k=1:6
if y(i+1)==k
z3(k)=z3(k)+1;
end
end
end
if y(i)==4
for k=1:6
if y(i+1)==k
z4(k)=z4(k)+1;
end
end
end
if y(i)==5
for k=1:6
if y(i+1)==k
z5(k)=z5(k)+1;
end
end
end
if y(i)==6
for k=1:6
if y(i+1)==k
z6(k)=z6(k)+1;
end
end
end
end
figure(1)
bar(x,z1), title('followers of 1')
figure(2)
bar(x,z2), title('followers of 2')
figure(3)
bar(x,z3), title('followers of 3')
figure(4)
bar(x,z4), title('followers of 4')
figure(5)
bar(x,z5), title('followers of 5')
figure(6)
bar(x,z6), title('followers of 6')
It's quick and was simple to write. From each z (ie. z1 to z6) you have the number of times each number follows it. Knowing the total population size and the variation in numbers you can easily get a percentage of what number follows what.
Greg- I'm sure your code is better. But I'm not sure how you utilized that interesting line.
[peace]
Fe
Also should be able to put those 6 'if' loops in a single 'for' loop to compress the size.
just a thought,
Fe
num_spots=input('How many spots ');
num_trials=input('How many trials ');
for i=1:num_spots
for j=1:num_spots
x(i,j)=0;
end
end
for i=1:num_trials
z(i)=1+floor(num_spots*rand(1));
end
tic
for i=1:(num_trials-1)
x(z(i),z(i+1))=x(z(i),z(i+1))+1;%was the interesting line
end
toc
x
Cheers
Greg Locock
Thanks a lot guys!
Glad to help. By the way, I always thought the term 'state-transition matrix' was used in control engineering.
[peace]
Fe
That's why I didn't reply. Had I known it was a regular ML golf problem, I may have played.
- Steve
There's a state; it transitions to another state...
TTFN
FAQ731-376
BrCo:
This exact question came up on CSSM last year. There are many ways to solve these sorts of problems. My favourite is to use the sparse() function:
% Some data with repeated sequences
x=[1 6 1 6 4 4 4 3 1 2 2 3 4 5 4 5 2 6 2 6 2 6];
sparse(x(1:end-1),x(2:end),1)
ans =
(3,1) 1
(6,1) 1
(1,2) 1
(2,2) 1
(5,2) 1
(6,2) 2
(2,3) 1
(4,3) 1
(3,4) 1
(4,4) 2
(5,4) 1
(6,4) 1
(4,5) 2
(1,6) 2
(2,6) 3
Or if you want it in array form, where A(i,j) holds the number of changes from i to j:
A=full(sparse(x(1:end-1),x(2:end),1))
A =
0 1 0 0 0 2
0 1 1 0 0 3
1 0 0 1 0 0
0 0 1 2 2 0
0 1 0 1 0 0
1 2 0 1 0 0
- Steve
Nice and simple. I never used sparse before.
What is CSSM?
[peace]
Fe
I was waiting for the one line answer!
Cheers
Greg Locock
It was my answer in CSSM, so I'm not plagiarising, just copying.
- Steve
Sorry, forgot a star for you. Slow isn't it?
where is that construction of x(1:end-1),x(2:end)
documented? What I mean is how does it 'know' that it can and should increment the pointer in each of the two x() statements together?
Cheers
Greg Locock
Greg,
Just look through the documentation for sparse(). In the form I've used, x(1:end-1) and x(2:end) are just two vector inputs representing the row and column for each of the elements in the third vector. For example, this produces a sparse version of eye(3):
sparse([1 2 3],[1 2 3],[1 1 1])
If the values of the elements are all the same, a single value can be (re)used:
sparse([1 2 3],[1 2 3],1)
This sort of assignment can't be done with normal arrays, there is no equivalent syntax (you run into all that sub2ind, ind2sub confusion).
Now the trick:
The neat (documented, but not obvious) thing about sparse()is that if a coordinate pair is repeated, the values assigned to it are summed, so this:
sparse([3 1 2 3 3],[3 1 2 3 3],1) gives
(1,1) = 1
(2,2) = 1
(3,3) = 3
So x(1:end-1) are the "from" coordinates and x(2:end) are the "to" coordinates. Each (from,to) pair is assigned a value of 1. Each repeat of a (from,to) pair increments the value at that location.
This is what I love about Matlab, sometimes it all just falls together.
- Steve
Thanks for the info on CSSM.
I wish I knew sparse existed before [pipe]
TTFN
Fe
Ah, ok it is a 'sparse' thing, not an indexing mode that I have yet to get to grips with (ie almost all of them).
Cheers
Greg Locock
