Parametrized input files 1
JayZ900807
Computer
Feb 27, 2009
17
Hello.
I am trying to open parametrized input files. I do this by importing them as models. However when i do this, a warning message always comes up:
WARNING: The input file contains one or more data items which have been parameterized. Parameterized input files can not yet be imported into Abaqus/CAE. This occurred while scanning input file for parameterized data. The input file will not be imported.
How can I overcome this problem, and open parametrized input files?!
Thank You
If you run abaqus datacheck, a .pes file will be created that has all the parameters converted to numerical results. Can you import that into CAE?
Hello mrgoldthorpe, and thanks for your help.
The thing is i cannot actually import the model. So i cannot do a datacheck, as there is no model defined.
Or am i doing somthing wrong. Sorry if you mean something else. I am still a fairly new user to Abaqus.
Can't you run datacheck outside CAE:
abaqus datacheck j=yourmodel
then run open the resulting odb file in CAE
To import a parametrised .inp file in CAE, first open it in any text editor and then replace the parameters with their values. CAE should be able to open the new file.
Aamir
Hey thanks for ur help people. I have got this problem sorted now.
Thanx again!!
