Nordern
- Apr 8, 2009
- 11
I work for a global company with 90% of our part design coming from Europe. As a result the European group controls the drawings. When I present these drawings to local vendors in the US the qoutes come back very high because of the metric shapes (square, round & rectangular tubes, mm size plate, etc.) Of course I can have the parts fabricated from inch size material and they will work just fine. The problem is that if I go to a "close" inch size the dimensions on the drawings are all off a little. Using dual dimensions helps with the the finished part but not the bill of material. I was thinking of having a 2 page drawing with metric on page 1 and imperial on page 2. I would also propose an alternate bill of material to cover the imperial dimensioned page. Has anyone ever done something like this or tried. Did it work? Thank you for any input.
