Dear ALL ,
I have two questions :
In general , the maximum working pressure for the ductile pipe for water systems is 350 psi , I have a design for water transmission pipeline with 25 bar working pressure , From your experience with the ductile pipe , IS IT OK to use ductile pipe for this system if the operating pressure is on the limit of the maximum working pressure for ductile ????
The second question is about the recommended type of restrained joints for the fittings (Bensd)of buried ductile pipe , The design calls for Mechanical joint fittings , my question , is it good to use mechanical joints for buried ductile pipe application , because I know for buried application it is recommended not to use bolted connections like the mechanical joints . From your experience with ductile pipes , is it better to use restrained Push-on joints bends instead of mechanical joints ?????
Thanks in advance.
Thanks in advance.
