Aggiedog
- May 17, 2009
- 2
Hello there! Been a lurker for many years while in school and finally took the plunge to register. I will try to contribute as much as I can (though I still have alot to learn).
I understand the very basics of what series and parallel pump configuration does to net head on flow capacity. However, for parallel configurations, I am a little unsure about NPSHR. I would assume that you would add each of the NPSHR for each pump and that would be that correct?
Also, if anyone knows of any good rotating machinary book I could use as a reference, I would appriciate it.
Thanks in advance!
Thanks in advance!
