Hello Everyone,
I have a special scenerio that some of you may have come across before. A house was built on a hillside in California. The driveway connects from the street down towards the garage entrance at about 12% slope. Onse side of the driveway is two to three feet away from a 4 foot retaining wall which basically retains the driveway. After this retaining wall there is a series of retaining walls that terrace down to retain basically the property as you move downhill.
The home owner is been asked to place a handrail by the HOA due to the difference in grade at the edge of the driveway/first retianing wall. While I have across the handrail requirements for staircases (where grade differential is more than 30 inches) and ramps, I do not see this requierement on any code for this application. While I agree with the application of the guardrail/handrail for safety purposes and it will be my recommnedation to the homeowner, can someone point me to any code that may have such a requirement for this scenerio? Any requirements or examples for such a situation in other states, counties, etc? Thanks.
