On a job I am working on, the electrical eng wants to run conduit through our composite slab. It is 3" deck with 4 1/4" concrete over the deck with 3/4" DIA. 6" long studs. In areas where conduit runs, he shows each flute with 2 1" DIA conduits running parallel and on top of each rib anothe 2 1" DIA conduit. This seems unacceptable to me, but what is general consensus? Are there any papers written on this or code recommendations on spacing, placement and maximum daiameter conduits??? I looked through ACI but didn't see anything regarding conduits. Thanks
