I'm trying to work with NXOpen.UF.UFCambnd.AskBoundaries(....) function.
I'm particularly interested in the FIXED_CONTOUR kind of operation with BOUNDARY drive method.
When I run, as a journal, this test code on such an operation it works perfectly well, meaning that it finishes successfully and doesn't through an error:
Option Strict Off
Imports System
Imports System.IO
Imports System.Windows.Forms
Imports NXOpen
Imports NXOpen.CAM
Imports NXOpen.UF
Imports NXOpen.Utilities
Module test
Dim theSession As Session
Dim theUfSession As UFSession
Sub Main()
theSession = Session.GetSession()
theUfSession = UFSession.GetUFSession()
Dim WorkPart As Part = TheSession.Parts.Work
Dim setupTag As Tag
Dim camObjectTag As Tag
Dim selectedTags() As NXOpen.Tag
Dim selectedCount As Integer
Dim lw as ListingWindow = theSession.ListingWindow
lw.Open()
theUfSession.Cam.InitSession()
theUfSession.Setup.AskSetup(setupTag)
theUfSession.UiOnt.AskSelectedNodes(selectedCount, selectedTags)
Dim i As Integer
Dim x() as IntPtr
theUFSession.Cambnd.AskBoundaries(selectedTags(0), CamGeomType.CamTrim, i, x)
lw.WriteLine(i)
End Sub
End Module
However, if I change CamGeomType.CamTrim to CamGeomType.CamDrive, it does throw an error, "Object is not the desired type".
I also tried to delete those boundaries with
theUFSession.Cambnd.DeleteBoundaries(selectedTags(0), CamGeomType.CamDrive)
and it didn't work either.
So, my question is, how do I get access to drive boundaries?
Option Strict Off
Imports System
Imports System.IO
Imports NXOpen
Imports NXOpen.CAM
Imports NXOpen.UF
Module test
Sub Main()
Dim setupTag As Tag
lw.Open()
Dim i As Integer
Dim x() as IntPtr
lw.WriteLine(i)
End Sub
End Module
