Hello all,
I'l looking for some suggestions on how to get the node co-ordinate data and element connectivity for use in a Vumat routine. I need to perform some integration with this data in my routine. The keyword list gives the coordinate of the material points and characteristic length of the element but this is not sufficient for my purpose. I would like to have lets say..the height/length of the element in z-dir.
Is it possible to get this through some keyword in Vumat? If anybody has an idea pls share.
Im using 3d brick elements with reduced integration.
