iyj
- Jan 27, 2010
- 26
Dear All
I hope you are fine and in best of health. I have started working on impact analysis and staright away some questions. I am using the same geometry that i used for contact analysis, the axisymmetric model using axisymetric elements.
Now what I am doing is that I have changed the analysis to dynamic explicit and instead of displacement i have given a initial velocity with the poin mass to the analytical rigid part. It works fine but But i want to see the impactor to impact the thick plate and than bounce normally as it happens in the real time.Do I assign gravity to the impactor or whats the slotion.
I want to see the force Vs indentation of this impact. I know you said I have to use different thread. I will make a new thread and post this on that too. Please helpBest regards
