nickatahi
- Jan 18, 2011
- 4
I'm driving myself crazy with a seemingly easy problem. I've got a hydraulic cylinder mounted horizontally with no support in the middle (see attached picture) and I'm trying to determine what effect the weight of the cylinder has on the critical buckling load in the gravitational plane.
Ignore the fact that this is a hydraulic cylinder. In general how do I approach this? I'm inclined to find the axial load that would create the same mid-length deflection and subtract that load from the critical buckling load to arrive at the 'adjusted' critical buckling load. I'm just not sure if that is valid to convert the lateral load to an axial one.
