Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...What a great service! This is the best site I've ever seen!!! It totally restores my faith in humanity when people take time out to help other people..."
Geography
petersi (Automotive)
9 Mar 11 11:11
I want to know if I can only need one mold will do what I need. For example, I'm going to make a plastic ball using glass filled composite. So, I make a mold for it. Then later I need a bigger ball, can I change the size on the mold? Then later, I need a smaller size of ball, can I change the mold size?
Or I need a few mold for different size of ball?
I need a cheap solution. thanks
patprimmer (Publican)
9 Mar 11 11:28
If you start with the smallest size but use a big enough bloc of material to make the biggest ball, you can do it by increasing the size, however it will cost almost as much as for a new mould as most of the cost is labour, not materials.
Decreasing the size is much more difficult.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
MikeHalloran (Mechanical)
9 Mar 11 12:48
Like Pat said.
But, balls are a special case.
You can hand lay up an ugly epoxy/glass sorta- ball over a balloon, which can be adjusted for size until the resin kicks.
Tooling doesn't get cheaper than that...
Mike Halloran
Pembroke Pines, FL, USA
Close Box
Join Eng-Tips® Today!
Join Us             Close
