Smart questions
Smart answers
Smart people
Join Eng-Tips Forums
Member Login
Remember Me
Forgot Password?
Join Us!
Join Eng-Tips now!
Join Eng-Tips
Jobs from Indeed
Link To This Forum!
Partner Button
Just copy and paste the
code below into your site.
plasticnoob (Industrial) (OP)
26 Apr 11 20:52
Sorry guys but i am not sure where i should post this.
I have a lot of polycarbonate parts with minor scratches so I try to remove the scratch by heating it.
Due to the lack of equipment, i was using a heat gun to heat up the polycarbonate hoping to reach its glass transition temperature. However i discovered that holes were formed instead. May i know what is the reason for this?
Helpful Member!(3)  patprimmer (Publican)
26 Apr 11 21:00
Because it melted.
flame polishing PC has several problems.
1) PC melt is very viscous so it does not tend to flow to smooth out.
2) PC absorbs water from the air over a reasonably short time. On heating this out gasses and forms bubbles on the surface and the gas also erupts like a mini volcano.
Using a hair dryer also has problems as it is a weak source of heat and the plastic transfers heat through its thickness due to the slow heating, this allows the material to melt all the way through. To flame polish you need to very quickly melt the surface while the matrix is still cold. A naked hot flame is the way to do that, hence the name, flame polishing.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
wongs9982 (Mechanical)
2 Sep 11 22:18
put a pin inside the hole,
then use flame to burn the flash.
should repair the mold by welding.
JMEMolds (Aerospace)
21 Sep 11 12:21
x2 on the naked flame, and for the same reasons.  A heat gun / hair dryer simply isn't going to work.
J&M Enterprises
Thermoforming Tools
http://www.jmenterprises.net
29 Dec 11 1:40
I see. Thanks for your help! i shall try using naked flame
Close Box
Join Eng-Tips® Today!
Join Us             Close
