Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I train people in ACCESS. I make sure they know about these forums, give them some training on how to use the site, and have a shortcut to it on their PC's..."
Geography
sizzer33 (Mechanical)
4 May 11 4:54
I would like to find out what is the most economical way to manufacture PMMA cubes with dimension of 25X25X25(mm). It will need light texture on the surface. Material to be used is Plexiglass PMMA 8N. I've only experience in injection molding and see that the part is not really feasible for this process. Any advice is appreciated.
thanks
Ken
patprimmer (Publican)
4 May 11 7:24
Cast it from PMMA casting resins.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
4 May 11 7:25
Alternativly machine it from 25mm thick sheet.
Pat
for site rules
MacGyverS2000 (Electrical)
4 May 11 9:27
I would machine it from bar/sheet stock (hmmm, I'm starting to sound like a broken record).  Someone else has already done the molding part, all you need to do is cut, possibly some media blasting to get your texture.
Dan - Owner
http://www.Hi-TecDesigns.com
5 May 11 2:11
Thanks for your suggestions. There will possibly be other shapes like half circle and cylinder shape. I'm actually wondering how some of these jewellers make the acrylic jewels because i'm thinking we would need suppliers like that.
So from your suggestions given, machining from PMMA stock would be a feasible way to do it for production phase. We're looking at 500,000pcs per month type of volume.
I saw in YouTube they do like plastic caps with compression molding and they were really fast. Can this be done with compression molding too?
5 May 11 4:04
At 500,000 per month I would injection mould with a lot of cavities in the mould.
I would estimate at least 2 minute cycle time, probably more like 3 or 4 min. Acrylic tap handles typically took about 90 sec I think.
That's about 12,000 a month per cavity 24/6 production.
That equals 45 cavities allowing for a few not working.
With a 24 cavity mould it would require about 10 tonne min clap and a 500 gram shot.
It would require at least 2 of these to keep up with production.
Other possibility is cell cast. Cycle time is a lot longer, but tooling is cheap so a few hundred cavities is feasible. Materials like acrylic sheet are traditionally cell cast from a pre-condensate or partially polymerized syrup.
Parts will weigh about 20 grams each or 50 per kg.
500,000 parts is 10 tonnes per month. Raw materials suppliers will be very happy to give you all sorts of advice as to how to make them either way if they believe you are for real and have a realistic project.
Pat
for site rules
5 May 11 5:30
Thanks Patprimmer. I guess we'd have to weigh in the pros and cons of injection moulding process & casting to see which are cheap and more efficient. Possibly will need to look for some casting suppliers.
From your experience in cell casting, could you advise typically how many cavity moulds you can build and whats the cycle time like? I would assume in production the whole casting process would be automated from putting in the liquid PMMA to ejecting the parts?
5 May 11 8:52
Probably it is not all that automated. Control of exotherm is the big issue. You heat it tocure it, but it is exothermic. To much of a start and it boils the monomer and makes bubbles. To little and it does not fully cure.
They cast acrylic sheet between flat sheets of glass clamped together with spacers of the required sheet thickness in between.
Pat
for site rules
Close Box
Join Eng-Tips® Today!
Join Us             Close
