mitchelg
- Nov 1, 2005
- 2
How do I calculate the temperature rise (or fall) of a liquid as it passes through a valve knowing the media (i.e. water), media density/specific heat, flow rate thru' valve, valve inlet temperature and valve inlet pressure plus pressure drop.
