Smart questions
Smart answers
Smart people
Join Eng-Tips Forums
Member Login
Remember Me
Forgot Password?
Join Us!
Join Eng-Tips now!
Join Eng-Tips
Jobs from Indeed
Link To This Forum!
Partner Button
Just copy and paste the
code below into your site.
petersi (Automotive) (OP)
25 Jul 11 9:46
HI,
I need to make this part, please see attachment. The company quoted me the mold is made of 718 steel, price is $1800. Do you think the price is right? thanks
MikeHalloran (Mechanical)
25 Jul 11 9:52
I would charge you more.
Pay the man.
Mike Halloran
Pembroke Pines, FL, USA
25 Jul 11 12:28
this part is so small. Like 6mm x 12 mm only. Sure your it worth that much? thanks
MacGyverS2000 (Electrical)
25 Jul 11 14:00
Mike... <chuckle>
Dan - Owner
http://www.Hi-TecDesigns.com
Danpkgeng (Mechanical)
25 Jul 11 15:17
When in doubt get a quote from somewhere else also.
patprimmer (Publican)
25 Jul 11 18:24
A lot depends on details not declared, including type of $ but US$1800 is a relatively cheap mould. Size is one factor. Detail, required finish, expected life, cooling channels, ejection details, draft angles required, precision of parts required, material to be moulded all have their influence.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
26 Jul 11 0:26
tomwalz (Materials)
27 Jul 11 11:33
The big thing is whether it works to your satisfaction.  Mold making is a lot of science and a lot of art.
I once "saved" money on a mold and then spent a lot of money sorting and hand-working the finished parts.
A littl less money for the first mold, a huge amount of rework and then the second mold.
Thomas J. Walz
Carbide Processors, Inc.
www.carbideprocessors.com
Good engineering starts with a Grainger Catalog.
ornerynorsk (Industrial)
27 Jul 11 16:23
There are only about a thousand details missing from your post, as Pat alluded to.  Also, the square shank, is it a hollow section or solid?
$1800 buys you almost nothing in this day and age as far as tooling goes, especially when constructed of Inco 718.  Is there a reason you need such "difficult" material?
27 Jul 11 21:12
Thanks, 718 is recommended by the mold maker. I need to product this part 10000pcs material abs 70%+30%pc.
27 Jul 11 21:12
Thanks, 718 is recommended by the mold maker. I need to produce this part 10000pcs material abs 70%+30%pc.
27 Jul 11 22:49
10,000 pieces only ever or per month or per year.
10,000 only ever is a very small number for injection moulding and the mould to last for such a short run could be even mild steel or aluminium so long as the moulder knows how to set up mould protection and avoid drools that might cause the mould to hob as it is closed.
PC/ABS is reasonably difficult with regards to drool and hobbing the mould as it is a relatively hard plastic and it absorbs water which can increase drool if not dried properly.
PC/ABS is not prone to differential shrinkage or warping so that is one less complication.
Pat
for site rules
Close Box
Join Eng-Tips® Today!
Join Us             Close
