majesus
- Aug 16, 2007
- 262
I have an application where I'm running 1000ft of parallel single conductors on tray across a site. I could use free air rating, however, there is one instance where I have to bury the cables to traverse a road and the buried segment is no more than 45ft. I will determine the conductor size assuming that the entire system is burried (worst case). However, as a hypothetical question: at what maximum buried length is the free air rating still valid? Say you have to bury the cable for a 3 ft length, does the cable require derating? (Think about when we connect a free air cable to switchgear. We can still have 3ft of cable running inside the enclosure to terminate at a breaker lug and that is similiar to an enclosed conduit.)
