  • Congratulations Danlap on being selected by the Eng-Tips community for having the most helpful posts in the forums last week. Way to Go!
best practice advice blending 1
uwam2ie
Automotive
Jul 11, 2005
1,008
I have question, how do you blend - which technic do you use to solve a problem like in the attached picture -tia
regards
Just looking at the picture it's kind of hard to tell what's up. May I suggest that you chop-out that piece and upload and I'll that a look. If you can't load the entire part than just create a block which 'swallows the pictured corner of your mode and perform an...
Insert -> Combine -> Intersect...
...operation selecting both your model and the block. Now either export the model as a Parasolid model and upload it, or go to...
Edit -> Feature -> Remove Parameters...
...blow away the features and upload that model.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Actually, it works with a .0001 blend radius, and I wouldn't even call that cheating.
And if you did do as mmauldin suggested, which BTW is one of the 'tricks' we recommend in situations like this were you're attempting to 'roll' a blend over what is in reality a 'sharp' edge, but you really need for that edge to have remained 'sharp', you could take mmauldin's model and export it out using the 'Heal Geometry' function and REMOVE all of those 'tiny' faces and still leave the blends behind. The model will be valid, just that the tiny little 0.0001 blends will be gone, replaced by new 'sharp' edges.
John R. Baker, P.E.
Industry Sector
Cypress, CA
I'm using Nx7.5.4 but nx 6.0 where also ok
thx
Blend the "outies" first, the ones your "innie" blends are going to cross over.
And in NX 8.0 we have given you a new Synchronous Modeling operation which will allow you to SWITCH the order of blends which cross, irrespective of the order you originally created those blend features in or even if they're actually blend features.
John R. Baker, P.E.
Industry Sector
Cypress, CA
I also recommend the use of variable blend points in cases like that
