Dimensioning an arc/spline Issue
chandragudla
Aerospace
Jul 29, 2011
16
thread561-270798
I am working with NX7.5, I have few concerns over arc length dimensioning in drafting.
1. As shown in the attachment how can i give arc length dimension
2. Some times there will be splines instead of arc, in such case how to give a arc length dimension
3. How to give arc length dimension for a curve/spline which is splitted into two segments
What is the best way of giving arc length dimension keeping in view of all the above points
As of now we are giving manual dimensions, Kindly help me to resolve the same
Thanks in Advance
Chandra gudla
To start with NX only supports the STANDARD for mot for 'Arclength' dimensions as below:
As for the 'Arclength' of a spline, you will probably have to construct something which looks like a dimension and then insert the length of the spline as measured. My advice would be to create a 'Parallel Dimension' between the ends of the spline. Then go into the Expression system, create a Measurement Expression for the length of the spline, then using...
Edit -> Annotation -> Text...
...edit the value of the dimension linking it instead the Measurement Expression. Now even if I edit the spline the 'Dimension' will update to reflect it actual length.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
UG/NX Museum:
Hi John,
Thank you for the reply, i tried your option of providing arc length dimension for splines and its working fine.
I found another method which is giving same results (i.e. arc length dim value is same for both methods) as well as associative with the models.
Please find the attachemnt for step by step procedure for the same.
Please let me know is this method feasible or not
Thanks & Regards,
Chandra Sekhar
 http://files.engineering.com/getfile.aspx?folder=aba9911b-3d69-49e5-9165-6e573927ea13&file=2011-10-05_163507.bmp
That would be fine for those situations where you have a spline which is basically representing an arc, which often happens when working with translated models. But if the shape is more general, then the approach I outlined would be better.
John R. Baker, P.E.
Industry Sector
Cypress, CA
UG/NX Museum:
