there is an option in "insertion point" command in SAP and ETAB say "do not transform frame stiffness from offsets from centroid"
the question are:
1-if we check or uncheck this box what will happen?
2-does this option have any important effect on ANALYSIS or DESIGN result?
3-when should we use insertion point command i mean we use it only when the frame section is too large or else
see file i attach
that all
thanks
the question are:
see file i attach
that all
thanks
